It is currently Thu Dec 04, 2025 4:49 pm
 Post subject: Speaker jack Question ?
PostPosted: Tue Aug 16, 2005 6:21 pm
Hello - Im hooking up the speaker jacks on my Lighting and I put the 4 Ohm jack between the line out and the 8 Ohm jack, so the 22K resistor goes from the hot of the line out to the hot of the 4 Ohm jack instead of the 8 Ohm jack. Will this be OK??
JOE
PostPosted: Tue Aug 16, 2005 8:10 pm
I suggest that you use the 8 ohm jack per the original layout.
