It is currently Sat Jan 24, 2026 12:48 pm
PostPosted: Fri Oct 15, 2010 2:15 pm
Hey guys, my name's Nathan. I just registered here to show you my new amp I just built.
A picture's worth 1000 words 8)
NAS_18W0001 by LITEFORCE, on Flickr
NAS_18W0008 by LITEFORCE, on Flickr
NAS_18W0004 by LITEFORCE, on Flickr
NAS_18W0003 by LITEFORCE, on Flickr
NAS_18W0002 by LITEFORCE, on Flickr
NAS_18W0006 by LITEFORCE, on Flickr
NAS_18W0007 by LITEFORCE, on Flickr
NAS_18W0001_1 by LITEFORCE, on Flickr
Hey, I've even got a video for you 8) http://www.youtube.com/watch?v=J4C_RwbeHtU
PostPosted: Fri Oct 15, 2010 5:49 pm
What can you tell us about your cool design?
PostPosted: Fri Oct 15, 2010 6:30 pm
Cool stuff Nathan,
Are all those transistor's driver's for the relays?
PostPosted: Fri Oct 15, 2010 8:23 pm
I used your sIII boost layout. Pretty similar with a few mods. Subbed some components for values I had, like all the 500k resistors are 470k, etc...
I moved the turret board, impedance selector and output transformer to fit everything in.
The relays, transistors and LEDs draw about 250mA worst case scenario (the board has 4 static states depending on the footswitch selection) so I used the torroidal transformer to power the accessories without straining the amps power transformer.
The TMB volume pot is a push pull for the sIII boost switch. The gain pot will be a diode clipper maybe, haven't installed the diodes.
The expander is kind of like the one on a Traynor YBA-1 but a bit simpler, currently it doesn't have a very strong effect, I think it might need another cap.
PostPosted: Fri Oct 15, 2010 8:26 pm
Cool stuff Nathan,
Yes the footswitch controls the drivers. The drivers control the LEDs and Relays. The signal path is all in the relays. I used a 100k resistor between the cascade like Stephen did in his build.
PostPosted: Fri Oct 15, 2010 8:30 pm
Resistors are metal film 1W or higher. No particular reason, I wanted to see what it would sound like with all new style components I guess.
There are 11 coax cables under the turret board :bugeye: . I actually don't have the specs on the cable, it just says made in Japan. I got it at Addison in Montreal, looks like 20AWG or 22AWG. I bought some at Active Surplus on Queen but then magically found this cable in my box of goodies when I actually set out to build this thing.
PostPosted: Sat Oct 16, 2010 3:56 pm
Looks awesome!!! :thumbsup:
:shock: :shock: Please no....!!! Promise me you won't do that to your beautiful amp. :cry:
PostPosted: Sat Oct 16, 2010 4:47 pm
Haha, why not!? It's a push pull so it'll be off normally. :happydance:
PostPosted: Wed Dec 01, 2010 6:02 pm
God the suspense is killing me, my head cab is in the mail. Stephen sent me a photo of it, looks beautiful! Should be here tomorrow.
PostPosted: Wed Dec 01, 2010 11:28 pm
I'll have to hear it some time soon.
PostPosted: Thu Dec 02, 2010 1:30 pm
Good lord that looks good!
Thanks Stephen.
PostPosted: Thu Dec 02, 2010 2:35 pm
Very cool design! Can't wait to hear clips
PostPosted: Thu Dec 02, 2010 8:58 pm
Looks good for sure. Not so sure about the 'Bluesbreakers' CD case tho!
