It is currently Tue Feb 24, 2026 11:07 am
 Post subject: TMB to TC-15
PostPosted: Mon Nov 23, 2009 9:29 pm
Hi
just wanted approval of first layout of TC-15
converting my TMB 18 to TC-15
any comments are welcome
and thanks in advance
http://i1018.photobucket.com/albums/af301/dcribbs1412/tc-15005.jpg
http://i1018.photobucket.com/albums/af301/dcribbs1412/tc-15001.jpg
http://i1018.photobucket.com/albums/af301/dcribbs1412/tc-15front1.jpg
PostPosted: Mon Nov 30, 2009 10:18 am
Sorry this is the second layout
anybody have any comments
just wondering if anything looks wrong
thanks
PostPosted: Thu Dec 03, 2009 8:08 am
Jumpers look fine; board parts look fine but cant confirm the values.
PostPosted: Thu Dec 03, 2009 10:16 am
Thanks for checking
I will post more pics as soon as I can
also thanks so much for the switch
PostPosted: Sun Dec 20, 2009 6:59 pm
some pics of the contour switch
http://i1018.photobucket.com/albums/af3 ... consw3.jpg
http://i1018.photobucket.com/albums/af3 ... consw1.jpg
http://i1018.photobucket.com/albums/af3 ... consw2.jpg
caps are .01 .0047 .0022 .0015 500pf 360pf
edit found I had 2 .0047 changed to 500pf mica will this work ok?
didnt have a .0005 cap
http://i1018.photobucket.com/albums/af3 ... swrev2.jpg
http://i1018.photobucket.com/albums/af3 ... swrev1.jpg
Happy Holidays to everyone :D
PostPosted: Mon Dec 21, 2009 8:56 pm
I'm a little confused about what you're saying....
0.0047uF is 4.7nF or 4700pF
0.0005uF is 500pF
PostPosted: Tue Dec 22, 2009 1:51 pm
Sorry for the confusion
after posting 1st pics I realized I had put a 472k (cap far left) where a .0005 cap was called for
before pic:
After pic:
So caps go 360pf 500pf .001 .0022 .0047 .01
this is what I had on hand
Thanks for looking zaphod
will the silver mica make much difference from poly?
PostPosted: Wed Dec 23, 2009 3:17 pm
Silver mica should be fine.
FYI - http://greygum.net/sbench/sbench102/caps.html
PostPosted: Wed Dec 30, 2009 12:14 am
little more work on the conversion
got the unibit to enlarge the chassis for the 5AR4 (octal socket)
the monsta bit:
http://i1018.photobucket.com/albums/af301/dcribbs1412/tc-15013.jpg
had to move the fuse assembly out of the way but otherwise no big deal to drill out...wired 290v to pins 4 and 6...5v to pin 2...0v to pin 8 :
http://i1018.photobucket.com/albums/af301/dcribbs1412/tc-15011.jpg
remembered to use the 5v tap(yellow/white) and tie off the 6.3v(white) I used for the 6CA4(EZ81)
hope I read this right:
http://i1018.photobucket.com/albums/af301/dcribbs1412/tc-15012.jpg
http://i1018.photobucket.com/albums/af301/dcribbs1412/tc-15.jpg
again any comments are much appreciated
Have a Happy Safe New Year :D
PostPosted: Fri Jan 01, 2010 10:30 pm
had a chance to do a little more
decided to go with a 4 H choke/1K5 resistor DPDT switch...on off on
we'll see if it works out
http://i1018.photobucket.com/albums/af301/dcribbs1412/tc-15014.jpg
http://i1018.photobucket.com/albums/af301/dcribbs1412/tc-15020.jpg
set the board in to see if it fit looks good.... got some leads to run
debated about the Hall VVR(thanks Dana) I'm going to give it a shot
http://i1018.photobucket.com/albums/af301/dcribbs1412/tc-15016.jpg
Also ran new shielded cable its big but all I had on hand
as always any comments are welcomed
PostPosted: Sun Jan 03, 2010 12:56 am
Got a little more done ....think I'm close firing it up...maybe fire is the wrong word...:lol:
few pics
http://i1018.photobucket.com/albums/af301/dcribbs1412/tc-15021.jpg
http://i1018.photobucket.com/albums/af301/dcribbs1412/tc-15023.jpg
http://i1018.photobucket.com/albums/af301/dcribbs1412/tc-15022.jpg
http://i1018.photobucket.com/albums/af301/dcribbs1412/tc-15026.jpg
http://i1018.photobucket.com/albums/af301/dcribbs1412/tc-15025.jpg
As always I appreciate any/all comments
please let me know if anyone spots a potential problem
I will post/check voltages as soon as possible...and I have a cold one
http://i1018.photobucket.com/albums/af301/dcribbs1412/tc-15024.jpg
PostPosted: Sun Jan 03, 2010 8:21 pm
Ok got some voltages
some look ok some dont
any help is appreciated
tubes installed
Pin| 1 2 3 4 5 6 7 8 9
V1 | 348 -- 6.4 -- -- 348 -- 6.5 --
V2 |205 -- 0 -- -- 282 -- 205 --
V3 |353 -- 6.6 -- -- 353 -- 6.6 --
V4 | -- -- 7.8 -- -- -- 369 -- --
V5 | -- -- 7.8 -- -- -- 369 -- --
V6 | -- -- -- -- -- -- -- 389 --
V7 | 68 -- 1.6 -- -- 123 -- 1.7 --
caps measured:
226 360 343 285 360
V1 seems pretty high also V3
again any input would be appreciated
thanks
PostPosted: Tue Jan 05, 2010 12:07 am
Well took another look and found some wrong resistor values :oops:
1.5m instead of 1.5k duh
none on hand ... placed order
will update when I replace
PostPosted: Sun Jan 10, 2010 11:49 pm
Got the 1.5k resistors and now voltages seem fairly good
amp sounds good all pots and switches seem to be working fine.Thanks Stephen another great design:D
V1 | 133 -- 1.3 -- -- 133 -- 1.3 --
V2 |170 -- 1.2 -- -- 268 -- 170 --
V3 |238 -- 44.9 -- -- 248 -- 46 --
V4 | -- -- 7.3 -- -- -- 359 -- --
V5 | -- -- 7.3 -- -- -- 361 -- --
V6 | -- -- -- -- -- -- -- 372 --
V7 | 68 -- 1.6 -- -- 119 -- 1.6 --
caps are 234, 315, 330, 266, 327
will be putting in cab and testing,maybe trying different tubes also
more pics to come
PostPosted: Sun Jan 24, 2010 11:56 pm
Some pics of the chassis in the wood
sounds good...... :D
going to break in before any tweaks
http://i1018.photobucket.com/albums/af301/dcribbs1412/tc-15027.jpg
http://i1018.photobucket.com/albums/af301/dcribbs1412/tc-15036.jpg
http://i1018.photobucket.com/albums/af301/dcribbs1412/tc-15028.jpg
PostPosted: Mon Jan 25, 2010 12:40 am
Beautiful cabs!!!!! 8)
Deric®
PostPosted: Mon Jan 25, 2010 10:14 am
it's 3/4" mahogany from a drawer company in Phoenix
guy I did computer work for has a wood CNC machine in his shop 8) did the detail work
I will post some sound clips as soon as I can
What to build next? :wink:
PostPosted: Mon Jan 25, 2010 10:26 am
Very nice detail. I really like that!!
PostPosted: Mon Jan 25, 2010 11:06 am
Thanks Stephen
I was hoping to create a nice home for your chassis.
Got some NOS tubes and a few different speakers I'm going to mess with. Then record some sound clips.
 Post subject: ef86 Channel
PostPosted: Wed Jan 27, 2010 7:45 pm
channel 2 sounds really good
but I have to turn volume way up on channel 1 to get acceptable volume(a long with quite abit of hiss)
I've done searches and checked res values, pot values,continuity and
changed tubes, but I'm not sure the ef channel should have this much
difference in volume.
thanks
