It is currently Tue Jan 20, 2026 9:29 am
PostPosted: Sun May 24, 2009 11:04 am
Got it up and running, and it SMOKES!!
Just out of curiousity, how much noise reduction would I get if I changed to metal film, and is there much of a change in tone? In other words, is there really something to the carbon comp thing, or is it just the "mojo juice."
PostPosted: Sun May 24, 2009 3:15 pm
http://www.geofex.com/Article_Folders/c ... oncomp.htm
PostPosted: Sun May 24, 2009 6:33 pm
Short discussion in the manual and posted here.
viewtopic.php?t=1290
It's not just mojo juice, but you can quieten it down a bit.
So, has anyone tried any resistor subs to reduce hiss & could recommend a mod or two?
PostPosted: Sun May 24, 2009 8:57 pm
Changing resistors of 100k and above to 1W metal film should help reduce a good bit of hiss. Lower noise preamp tubes can also help a lot. For example, New Sensor's "Mullard" 12AX7s have lower noise levels, and sound real good into the bargain. :D
PostPosted: Tue Jun 02, 2009 10:55 am
You compared those to a tung sol Phil? I thought you were a NOS only guy.
PostPosted: Tue Jun 02, 2009 1:27 pm
I almost entirely use NOS tubes in the amps I build for my own use. However, I've had to admit these new fake Mullards from New Sensor do actually sound pretty sweet. :shock: In appearance they also have the same "ladderplate" style anodes as my NOS Mullard and Brimar 12AX7s. So it looks like they have reproduced Mullard's electrode geometry, or at least made a pretty good attempt at it.
Apparently there are some fake Mona Lisa paintings out there too, that even art experts have trouble telling apart from the real one. :lol:
Users browsing this forum: Google [Bot] and 40 guests
