It is currently Tue Jan 20, 2026 5:13 am
PostPosted: Sun Apr 29, 2007 1:36 pm
see also: http://18watt.com/modules.php?name=Foru ... 785#165069
PostPosted: Sun Apr 29, 2007 1:49 pm
yep, been reading that with interest.
Jac
PostPosted: Thu May 17, 2007 4:15 pm
Just to jump back in, I've begun building the Vajra. I won the Mark Durham Giveaway Grand prize. S2 didn't have time to make it, so we agreed for him to send me a 'kit' so I could make it myself.
So I ought to find out pretty soon how the Vajra is.
If anyone would like, I'll upload the layout I just finished (and uploaded to 18watt.com last night) along with a drilling guide. The layout assumes you're using Heyboer transformers on an 18 watt style chassis.
It's still a drag 18watt.com closed shop...
Richard Johnson
PostPosted: Thu May 17, 2007 4:49 pm
Oh, Please,m Please. I would love to see the layout.
Thanks, Rjgtr.
Later,
JAC :D :D :D :D :D :D
PostPosted: Thu May 17, 2007 8:11 pm
Yeah, way to throw the baby out with the bathwater.
PostPosted: Thu May 17, 2007 10:58 pm
I removed the layout. I updated it and since 18watt is back on line, you can check the new version in my Gallery there.
Richard Johnson
PostPosted: Thu May 17, 2007 11:26 pm
Thank you very much,
You'll have to excuse me, I'm putting the chassis parts together for the EF-86. :D I kinda get lost in thought :D :lol:
Did you really fit all that in the Brownnote chassis? How? That board looks HUGE! :shock: I remember from your original thread that you went with a brownnote chassis, as it was smaller.
Again, thank you,
Jac
PostPosted: Thu May 17, 2007 11:37 pm
Oops, wrong amp.
I wanted this one very much too. :?
That's what happens when you build at your computer desk :lol: :lol:
So many amps to build, so little time. :D :D :D :D
Do have a question already though, as I take a break.
Why is the 1st terminal on the terminal strip grounded? Seems pointless as it doesn't connect to anything.
PostPosted: Thu May 17, 2007 11:52 pm
Just the way they're made. Some stips aren't. You have to be careful not to attach a power line to it! :shock:
PostPosted: Fri May 18, 2007 12:01 am
OKAY :shock: :lol:
PostPosted: Fri May 18, 2007 12:04 am
Coco, as long as your here.
If you saw , I'm going to use the 270fx hammond for now. You think that's to much voltage for the lite. Maybe I should change to an octal rectifier( drill it). Before I get to far? To bring down possible additional voltage.
What do you think?
PostPosted: Fri May 18, 2007 12:08 am
Wait till you see, I painted the hammond chassis a god awful metallic blue :shock: . It's GREAT! :D :D
PostPosted: Fri May 18, 2007 10:11 am
Just ignore it. That's what I get for reusing another layout! Plus as coco says, they're always grounded.
Richard Johnson
PostPosted: Sat May 19, 2007 8:27 am
jac wrote:
If you saw , I'm going to use the 270fx hammond for now. You think that's to much voltage for the lite. Maybe I should change to an octal rectifier( drill it). Before I get to far? To bring down possible additional voltage. What do you think?
Yes, You should drop some voltage IMO.
PostPosted: Sun May 27, 2007 12:29 pm
I got some of those anti-vibration rings off a guy on eBay. I don't remember who exactly it was. Also, why doesn't someone try out some 6BR7s. You can use them like EF86s, but they're resistant to microphonics. Just beware that they have a different pinout, so you have to change the socket wiring.
PostPosted: Sun May 27, 2007 12:48 pm
I Also, why doesn't someone try out some 6BR7s. You can use them like EF86s, but they're resistant to microphonics. Just beware that they have a different pinout, so you have to change the socket wiring.
That is something I'd like to do some day..
PostPosted: Tue Jun 19, 2007 7:29 pm
I have just put an amp together with the Vajra EF86 channel at the front and Phils P1x power amp running a EL34. It sounds sweet but I have to work on a second stage gain area as it could do with a little more poke. Pictures/clips coming later in the Dressing Room.
Nigel :)
PostPosted: Tue Jun 19, 2007 8:32 pm
Legin wrote:
I have just put an amp together with the Varja EF86 channel at the front and Phils P1x power amp running a EL34. It sounds sweet but I have to work on a second stage gain area as it could do with a little more poke. Pictures/clips coming later in the Dressing Room.
Nigel :)
You have time to do that? Impressive. Looking forward to your build notes / clips. You should start a new thread on developing that one. What are you calling it??
So this would have three tubes? EF86, 12AX7, EL34?
PostPosted: Tue Jun 19, 2007 10:01 pm
Stephen yes that is what it will end up with, I am currently running just the EF86 and EL34, at mid levels it has a great jazzy vibe with just a hint of crunch, I want to get that same sound but lift the gain a tad and I am thinking a half a 12AX7 may do the trick. I will have to think of a new mythological creature.
Nigel
