It is currently Mon Sep 28, 2020 9:14 pm
PostPosted: Wed Jun 06, 2012 5:22 pm
I've been lurking around here, looking hard at this amp for a build. Some questions for those in the know.
Does the Triwatt have enuff headroom with the KT66s to play clean and keep up with a drummer unmiked?
Talkin' funk/country etc clean........with a 2 12 cab.
Do you have to buy the "factory build" to get the foot switchable option for the gain/boost?
And if you can get that with the kit, are the proper holes punched in the chassis, to facilitate this addition?
PostPosted: Wed Jun 06, 2012 8:23 pm
Hell's yes! No doubt about this.
Pretty sure you can get a footswitch add on kit with your amp kit. Probably a small up charge but it would include all the parts along with the chassis all nicely punched for you. O and documentation too!
PostPosted: Thu Jun 07, 2012 11:38 pm
Even with the docs, it's not easy to figure out, even after you've built a few. Personally, I don't recommend DIYing the footswitch option - and I don't even think it's really all that necessary.
PostPosted: Sun Jun 10, 2012 7:57 am
Could you elaborate a bit on that point? why is it difficult, why unnecessary?
This feature is one of the reasons I was looking at this design.....
HW sound with a gain/boost feature (would be a very useful feature to me for gigs).
Yeah, I know I could hit it with a pedal, etc but, I like onboard amp gain boosts if possible first, then pedals.
PostPosted: Sun Jun 10, 2012 8:19 am
The Boost switch is on a push/pull pot that's real easy to operate, unless you really need to play 20 feet away from your amp. Unless you're a fairly experienced builder, the extra circuitry for the pedal and relay carries a genuine risk of introducing hum/buzz and oscillation into the amp. We're talking of boosted gain levels equivalent to a Soldano here, so the construction is real critical.
PostPosted: Sun Jun 10, 2012 8:39 am
That's exactly what would be going on.......well, maybe 5 or 10 feet (I wish the stages I play were that big ;-)
On the fly, mid song, gain boosting, etc.
I have electronics experience (my dad and uncle had a repair/sales shop from the early 70s til the early 90s, that I worked in for most of that time period as a kid and on, we did TV/Stereo/VCR/MW, etc repairs and I even used to sell records there as well ;-)
So, while this would be my first amp build, I have time behind a soldering iron inside of various types of chassis's, also do my own work on my amps as well these days.
I'll take what you say under advisement.........and bug the hell out of you guys if I get the option and run into trouble. ;-)
PostPosted: Tue Jun 16, 2020 1:21 pm
To your question, a resounding yes. Plenty of volume !
PostPosted: Tue Jun 16, 2020 5:30 pm
You might want to get your overdrive from pedals like. This way you have all your gain on tap and you can use different pedals to get certain tones.
Hell yeah, I am using a powerbooster, tube driver, russian muff and a rams head muff. Each has its own unique tones and the best part is: they all work brilliantly with the Triwatt. Seriously, it loves all pedals!
PostPosted: Wed Jun 17, 2020 8:10 am
Is it the EHX Green Russian? If so how do you find it ?
PostPosted: Fri Jun 19, 2020 4:57 pm
Just want to add another endorsement of this use-case. Before coronavirus, I was doing regular band rehearsals with my 6V6-powered Triwatt in a 1x12 combo cab. I think our drummer is average in terms of loudness. Clean headrooom volume was definitely not a problem. IIRC, I had the master around 10:00 or 11:00. I like to run my Triwatt where the preamp is on the verge of breakup; so I was running through the linked input, with both pre-amp volumes somewhere between noon and 3:00. (And if I was the only guitarist, I'm certain I could get away with even lower volume---the other guitarist is louder than our drummer!)
While the classic 100- and 50-watt Hiwatts are famous for being obscenely loud, I think I'd call the Triwatt "manageably loud". I struggle to imagine a scenario where you'd need more volume than what the Triwatt can produce.
Keep in mind, we perceive sound logarithmically. So, all things being equal, a 50 watt amp is not half as loud as a 100 watt amp; a 10 watt amp is half as loud as a 100 watt amp. Emphasis on all things being equal - in practice, they almost never are. But with the Triwatt vs classic Hiwatt, things are about as close as they can be: the preamp is the same(*), and the transformers are believed to be a faithful reproduction of the ones used by classic Hiwatts (meaning they are over-spec'ed for 6V6 and KT66 operation).
(*) to be pedantic, there are multiple versions of the Hiwatt preamp - so even between two actual classic Hiwatts, all things may not be equal.
PostPosted: Sun Jul 05, 2020 1:22 pm
It's awesome! I am using a Buffalo FX rams head as may rams head muff (think The Wall) and the EHX Green Russian for later Floyd stuff (think Sorrow).
Based on my experience and everything i have read on the internet, the EHX Green Russian is almost the exact same sound as the vintage version of it. Albeit a chunk cheaper and smaller in term of pedalboard footprint.
