It is currently Thu Mar 28, 2024 4:57 pm
Tube Amp Troubleshooting
1) Plate resistor.
Measure 4 with a voltmeter.
Other Tests
Noise or cracking.
LEAD DRESS
Users browsing this forum: Google [Bot] and 13 guests
