It is currently Thu Jan 22, 2026 9:08 am
PostPosted: Fri Oct 28, 2005 6:22 pm
I was finally able to get some shots of my scratch built Twisted Spitster.
and....
Stephan, next time I get the urge for a new amp, I'm having you build and cover the cab!!! I don't have that kind of patience anymore!!!
PostPosted: Fri Oct 28, 2005 10:54 pm
Looks prety darn good to me! Good job. I'd really like to hear clips. I've been looking for an octal pre stage and I'd like to hear it.
Thanks for the pics
PostPosted: Sat Oct 29, 2005 7:50 pm
Stephen, I will see what I can do about that. Thanks for the comments! :lol:
PostPosted: Sat Oct 29, 2005 10:06 pm
Very nice work! 8)
PJM
http://www.diyguitarist.com
PostPosted: Mon Oct 31, 2005 9:02 am
Thanks Paul! :D
PostPosted: Wed Nov 02, 2005 10:50 am
8) Very nice job Dude!
CR ><>
WoodCross Amps
PostPosted: Sun Nov 06, 2005 8:40 pm
awesome, I've contemplating a octal pre myself. Cool looks too.
PostPosted: Mon Nov 07, 2005 9:09 am
:D Thanks Maccabee!
:D Thanks Brian!
5e3 sized cab with modern covering. I'm real happy with the way the octal preamp and PI turned out. Everybody needs at least 1 amp set-up this way!
PostPosted: Tue Nov 08, 2005 12:00 am
How are you liking that BlueDog? I have a 15watt alnico at 16 ohms paired up with one of BBQ's 12h30 55hz clones at 16 ohm in ceramic. They work pretty well together. The ceramic is just a little bit more forward sounding. It could very well be my ears , tho.
Nice build, by the way. Let's hear it!
LeeMo
PostPosted: Tue Nov 08, 2005 9:27 am
:D Thanks LeeMo!!! I love my 30watt Alnico Blue Dog
Yes I want to get that baby recorded!!!! A buddy of mine just got a Tascam 8 track hard drive recorder, but he has a lot to learn before we can get something down.
PostPosted: Wed Nov 09, 2005 9:39 pm
Thats a Sweet build Twang ! Im curious about the large resistor that you have off the power switch, what are the details on that?? Is it there to lower you wall voltage ? if so what value is it and what was the voltage drop?
Also it looks like someone got a Tig welder for christmas - Did you build the chassis? nice penatration on those fused corners.
JOE
PostPosted: Thu Nov 10, 2005 9:21 am
Thanks Joe, :lol:
That power resistor is dropping the wall voltage a bit. It's a 10ohm 10watt wire wound. That dropped my heater voltage from 6.5-6.6v range down to 6.2v range. Also it brought my plate voltage on the el84's down about 10 volts to 325.
I had the Komboking build me 2 of those chassis. I'm going to build a 5e3 deluxe next. I built 3 deluxe style cabs, sold 1 and kept 2 for my own builds.
PostPosted: Sun Nov 13, 2005 6:00 pm
I employ this same trick, using the same resistor, a 10-ohm 10-watter. For me it has the same exact result. It brought my B+ down from 380 down to under 360...and dropped my filaments from 6.7v to 6.3
-F
PostPosted: Thu Nov 17, 2005 12:38 pm
:D B&V, I believe I got that idea from reading 1 of your posts! :lol:
