It is currently Wed Jul 15, 2026 1:36 pm
 Post subject: Vrm Issue plexi
PostPosted: Thu Mar 22, 2012 7:19 pm
When I installed this all hear is a sizzle and then the main fuse blows when I throw the stby switch
From the board yellow wire went to the stby switch
Green wire went to ground
White wire went to the first side of the cap
The wires from the pot are the same as if the pot was directly soldered to the board
I've pulled it all out and hooked up the amp standard and all is fine
I have pulled the mosfet out and tested it still test the same as before I put it in.
Tested the diode and its fine
By sazafraz at 2012-03-22
 Post subject: Re: Vrm Issue plexi
PostPosted: Thu Mar 22, 2012 9:08 pm
Oh dear!!!!! I've been building my 18 watt plexi today & I have installed the vrm today ,I hope it works out for me .I guess i will find out in a day or 2
