It is currently Wed Jun 10, 2026 4:46 pm
Post new topic Reply to topic  [ 46 posts ]  Go to page 1, 2, 3  Next
PostPosted: Thu Apr 08, 2010 12:21 pm
Hi I've just finished my first 18 TMB build thanks to help from this board, many thanks for that.
Are my V2 numbers on the low side?
V2- pin1 149
pin3 0.94
pin6 265
pin8 150
my guide gives pins 1 and 8 nearer 180
the rest of my numbers appear to be within spec, any ideas?
Cheers
PostPosted: Thu Apr 08, 2010 12:53 pm
Ya that is a little low.. What do you have at the + end of the 16uf cap adjacent to V2?
Stew
OOps never mind I see 265..hmmm... Hows voltages on V1? Is that 100k across the tube socket (v2) correct? Not damaged ect.
Stew
PostPosted: Thu Apr 08, 2010 1:09 pm
101k across the V2
V1 numbers
pin1 149
pin3 0.99
pin6 147
pin8 0.95
V3
pin1 207
pin2 54
pin3 79
pin6 208
pin7 53
pin8 79
V4 & V5
pin3 12.8
pin7 354
pin9 336
V6
Pin1 310
pin3 367
pin7 310
cheers
PostPosted: Thu Apr 08, 2010 1:36 pm
Hmm ..OK..check the V on pin 7 of v2. And the 8.2K resistor near the powersupply end of the board.
Stew
PostPosted: Thu Apr 08, 2010 1:54 pm
The V on V2 pin7 is 149 and the 8.2k power end is reading 8.08k
cheers
dave
PostPosted: Thu Apr 08, 2010 2:21 pm
Very interesting :hmmm:
Could you check the 3 tMB pots and make sure there's no dc on any of the contacts.
PostPosted: Thu Apr 08, 2010 3:06 pm
The TMB pots check out ok, no DC
cheers
dave
PostPosted: Thu Apr 08, 2010 3:24 pm
The 100k on the plate of V2 (pin1) is indeed a 100K? :?:
PostPosted: Thu Apr 08, 2010 4:23 pm
Yeah it measures 101k,
time for a cup of tea n some biscuits
cheers
dave
PostPosted: Thu Apr 08, 2010 4:28 pm
Have you tried swaping tubes and see it the problem follows?
PostPosted: Thu Apr 08, 2010 4:36 pm
Yes I tried it but the problem stays on the number 2
cheers
Dave
PostPosted: Thu Apr 08, 2010 5:07 pm
Well I'm grasping at straws here.. :roll: .but are all your grounds connected to that copper buss and is that buss connected to the chassis near the i/p jacks. It's almost like everything is correct except that the measurement rederences are offset :?
Unless phil or stephen can chime in you might have to upload some good clear photos of the board/tube sockets.
Stew
PostPosted: Thu Apr 08, 2010 8:38 pm
OK, I think the ground at the cap connected to pin 8 is not grounded properly. resolder. test with continuity meter. This is why you have high voltages on pin 8. that is throwing the rest of that triode off kilter too.
PostPosted: Fri Apr 09, 2010 10:38 am
Ok, I've resoldered all the grounds, checked the bus bar & star points, checked the continuity all good, the low voltages are still there.
V2 - Pin 8 & pin1 still only showing 150, and only 0.94 on pin3
cheers
dave
PostPosted: Fri Apr 09, 2010 12:28 pm
Just a quicky....what's your filament voltages?
Also can you check the Rs on both cathodes of V2 pins 3 & 8.
PostPosted: Fri Apr 09, 2010 12:58 pm
6.7 across them all for the heaters
For the resitamce on the cathodes do I measure across 3 & 8?
cheers
PostPosted: Fri Apr 09, 2010 2:17 pm
cheers
No ..cathode to ground (power off of couse).. Just trying to figure out if that 1.5 v you have vs the proper 0.9-1.0v is caused by an incorrect cathode resistor.
PostPosted: Fri Apr 09, 2010 2:29 pm
If that checks out power her back up and check for DC on the grid (pin 2 V2).
PostPosted: Fri Apr 09, 2010 2:32 pm
I think I should have 1.5v but I've only got 0.94 on pin 3
resistance on pin 3 is 863 & pin 8 is 58k
I'm not seeing any DC on pin 2, to be clear pin2 power on to ground?
Dave
PostPosted: Fri Apr 09, 2010 4:41 pm
