It is currently Thu Feb 05, 2026 8:13 am
 Post subject: TC 15 Transformers
PostPosted: Wed Nov 26, 2008 12:04 pm
What transformers would yall recomend and where to find them?
Andy
PostPosted: Wed Nov 26, 2008 1:27 pm
Trinity transformers of course! Right here from Stephen...
AJC
PostPosted: Wed Nov 26, 2008 2:01 pm
All I see is the 18 watt transformers. Is this the transformer he uses for all his amps? If so are they beefed up like the matchless amps?
Andy
PostPosted: Wed Nov 26, 2008 7:05 pm
The original 15 used Matchless transformers (I have one). The TC 15 uses the Trinity transformers (I have one as well). I tyhink they are the same as the 18 set, there is a 5 and 8K ohm output. Physically they are similar sized to the Matchless, but there is no choke on the TC15 like there was on the original 15.
AJC
PostPosted: Wed Nov 26, 2008 7:14 pm
Thanks, one more question. I see a reference to the crunch and munch
switch. What is it?
Also with the tc 15 when you jumper the channels do you get the typical fatter sound with increased gain? Never jumped a amp with the 86 tube.
Andy
PostPosted: Wed Nov 26, 2008 8:19 pm
AndyG wrote:
Thanks, one more question. I see a reference to the crunch and munch switch. What is it?
Andy
The crunch and munch switch switches between the 5K and 8K ohm impedance taps on the transformer and gives a overall tonal change - crunchy (with a bite) or munchy (smooth).
When you jump the channels you get a bigger, more complex sound with increased gain and tone control.
PostPosted: Wed Nov 26, 2008 9:25 pm
Coco could I just buy the chasis, transformer and eyelet board?
Andy
PostPosted: Wed Nov 26, 2008 9:58 pm
Go here: viewtopic.php?t=604
