It is currently Sun Jul 12, 2020 8:23 am
 Post subject: Need some ID help
PostPosted: Mon Feb 04, 2019 4:06 pm
Got this kit built 18 water recently. The guy I got it from was clueless as to who built it much less who made the kit. It's got a 20" chassis and the only one I've been to determine as having this size chassis is Trinity. This was built in 2013, does this look like a Trinity amp kit? What schematics would match it? And are there any gurus who can help figure out a slow pulsing going on in the background on this amp. Thanks in advance.
 Post subject: Re: Need some ID help
PostPosted: Mon Feb 04, 2019 4:59 pm
Ok looking at the pic I decided to check online and see what GDSwould turn up. OK it’s not a Trinity. Still looking for help on the pulsing.
PostPosted: Mon Feb 04, 2019 7:12 pm
Some sort of 18watt TMB with a plexi flare would be my guess. don't now who's layout it is . But I do see the phase invierter as the second tube .
Theres may layouts for this.
This. looks like its close to yours except for the the firs two cathodes res/cap being reversed. http://site.triodestore.com/18WTMB.pdf
As for you pulsing issue is it in both channels volume up down ?
PostPosted: Mon Feb 11, 2019 11:48 pm
Def not trinity. Uses GDS iron and his style chassis s maybe...
PostPosted: Fri Feb 15, 2019 11:45 am
Found a closer layout
http://rh-tech.org/public/18-Watt/18_Watt_TMB.pdf
PostPosted: Fri Feb 15, 2019 12:19 pm
sazafraz wrote:
Yeah, probably that's the one. Nice layout but the order of the tubes in that design was always bad as was the location of the MV but Trinity changed all that!
