It is currently Tue Jul 14, 2026 12:18 am
PostPosted: Fri Mar 09, 2012 12:21 pm
I was wondering if anyone has added an additional filtering after the rectifer I was thinking of adding a 30ohm 500volt filter cap right after the ez81. JGK
JGK
PostPosted: Fri Mar 09, 2012 1:07 pm
By 30ohm I assume you mean 30uF?
Why do you want to do this?
The maximum reservoir cap the EZ81 can handle is 50uF so 60uF (two 30uFs in parallel) won't work. The best you can do is tack on another 20uF on top of the stock 30uF cap.
PostPosted: Fri Mar 09, 2012 3:54 pm
Your right 30uF had a brain cramp there. I have a little hum in the amp after working on the layout and moving wires and was wondering if an additional filter would help this. JGK
JGK
PostPosted: Fri Mar 09, 2012 5:58 pm
I'd try moving wires (lead dress) and swapping different tubes to reduce noise before making circuit changes (like adding additional filtering).
Increased filtering will change the tone as well as the ripple voltage (noise) too, just so you know.
