It is currently Wed Jul 15, 2026 2:48 pm
 Post subject: PT Wiring Question
PostPosted: Thu Dec 29, 2011 4:19 pm
Greetings. I am building the 18W Plexi version and have a power transformer question. My transformer has two 117V connections on the primary side. The manual advises that these are wired in parallel for 120V applications. Do I need to wire up both connections or will one suffice? Not sure if perhaps the secondary windings need to have both connected. If not I will cannibalize the wires for a cleaner run. Any help appreciated!
 Post subject: Re: PT Wiring Question
PostPosted: Thu Dec 29, 2011 4:38 pm
You need to wire up both and put the windings in parallel. Refer to the layout.
PostPosted: Thu Dec 29, 2011 4:54 pm
Got it. Thanks for the help!
