It is currently Wed Apr 15, 2026 5:26 pm
PostPosted: Thu Sep 12, 2024 10:47 pm
Hello, just wondering if there are tips in coverting a closed back to an open back cab. ie Take the middle 3rd out etc. Are their any specifcs that i should know or any info i could look at. I am buying a new piece of wood to make it, just incase i want to put it back together.
Thanks for any advise!!!
Al
PostPosted: Tue Oct 01, 2024 12:37 am
Hi all,
I think this approach not only reflects thoughtful thinking but also encourages experimentation with sound without committing to permanent change. It has highlighted the creativity and passion within the guitar community for customizing gear to achieve desired tonal qualities. geometry dash deadlocked
PostPosted: Thu Feb 12, 2026 4:57 am
Try opening a little portion first rather than removing the full middle third at once. You can adjust how open you want it to be because even a partial opening significantly alters the sound. blox fruits
PostPosted: Fri Feb 13, 2026 4:11 am
To convert a closed back cab to an open back, you can cut a section from the middle of the back panel. Here are two quick tips:
snow road
Size of the cut: Make sure the opening is large enough for sound to escape but not so large that it compromises the cab's structure.
Testing: After cutting, test the sound and adjust as needed.
Users browsing this forum: Majestic-12 [Bot] and 2 guests
