It is currently Wed Jul 16, 2025 4:25 am
PostPosted: Thu May 23, 2024 10:27 am
Hi all,
I just built a 18W TMB version and all the voltages are lower than the documentation, should I worry about it? Other than that the amp is working great.
Voltage Readings:
B+: 334V
V1 (ECC83)
Pin 1: 122V
Pin 3: 0.9V
Pin 6: 123V
Pin 8: 0.9V
V2 (ECC83)
Pin 1: 128V
Pin 3: 0.75V
Pin 6: 240V
Pin 8: 131V
V3 (ECC83)
Pin 1: 181V
Pin 2: 31V
Pin 3: 65V
Pin 6: 187V
Pin 7: 32V
Pin 8: 65V
V4 (EL84)
Pin 3: 11.75V
Pin 7: 330V
Pin 9: 304V
V5 (EL84)
Pin 3: 11.75V
Pin 7: 329V
Pin 9: 308V
V6 (EZ81)
Pin 1: 279V AC
Pin 3: 334V
Pin 9: 279V AC
PostPosted: Tue Jul 23, 2024 10:27 pm
The voltage readings you've provided for your 18W TMB amplifier seem to be a bit lower than the expected values
geometry dash online
PostPosted: Mon Jul 29, 2024 11:08 pm
Almost every application's power supply is different. If used properly, low voltage power is not a problem. You can read the source information to make the correct connection. coreball
PostPosted: Tue Feb 11, 2025 10:20 pm
lemaum wrote:
Hi all,
I just built a 18W TMB version and all the voltages are lower than the documentation, should I worry about it? Other than geometry dash that the amp is working great.
Your voltages are slightly low but not necessarily problematic. Check your transformer, wall voltage, rectifier drop, and cathode resistor. If the amp sounds great, enjoy it!
PostPosted: Wed Apr 09, 2025 3:44 am
You can check the power supply and make sure all the components are within spec, but if the amp sounds good and operates correctly, it's probably not a cause for immediate concern.
Snow Road
