It is currently Sat Jan 24, 2026 12:52 pm
 Post subject: PT hookup question
PostPosted: Sat Mar 19, 2011 8:58 pm
Wow! Can you believe it's taken me almost 8 years to finish this thing! I think I'm ready this time. I found all the parts and the half completed amp in my garage so I figure... go for it.
I'm building an sIII with Trinity Trannys (hell, these trannys probably go for a fortune now, NOS first run batch, lol). I have 2 PT wiring diagrams. One is the full diagram and the other is titled "High Voltage Wiring". The original shows the black/white lead going to the power switch, the HV Wiring one shows the black lead to the power switch. It appears that the two connections are switched in each diagram. Which one do I use?
Hopefully I get this thing done.
 Post subject: Re: PT hookup question
PostPosted: Sat Mar 19, 2011 9:23 pm
I did a little research and realized that the HV Wiring diagram is for S2 transformers.
PostPosted: Sun Mar 20, 2011 3:12 pm
On the mains, the "line side" of the power is switched, not the neutral. That is the important thing.
