It is currently Sun Mar 07, 2021 12:09 pm
 Post subject: Using a KT66
PostPosted: Wed Nov 28, 2018 10:35 am
Can a KT66 power tube be used in the Triton if an appropriate cathode bias resistor is used, as is suggested in the documentation for the Tramp? Also, would the output transformer primaries have to be switched to 2.5 K or left at 5K, again per the Tramp documentation? Any other things to consider, say heater current requirements, if I wanted to run a KT66 in a Triton? Thanks much.
 Post subject: Re: Using a KT66
PostPosted: Fri Nov 30, 2018 8:50 pm
Looking at the schematic it says the power trans has 1.5 amps of heater current avail
Coco will have to confirm
Kt66 draws 1.3 amps
6l6 draws . 9 amps. 6v6 draws less
6sj7 draws .3 amps
6l6 +6sj7 =1.2amps
kt66+6sj7=1.6amps
the only kt66 that I know of that draws .9amps is the new production tung sol
PostPosted: Fri Dec 14, 2018 12:48 pm
Transformer specs say it can provide 100mA at High voltage and 2.25 A heater current.
I expect it will power the heaters, the bias current should b fine too. Use the 4K bias tap.
