It is currently Wed Oct 09, 2024 8:27 pm
PostPosted: Sat Jan 23, 2021 6:50 pm
Finished up my TripTop build today. Found a few interesting voltage readings while doing the final check. Any help or advice would be fantastic
I tripled checked all my soldering points, resistor values and capacitor impedance. All are good and correct. Cathode based biasing is dead on at 39vdc
B+ Voltage is 419. Mains is 117v
-All of my above 100v test points are reading 20v lower than the target except for:
-Voltage on pin 2 and 5 on V2 are around 30v higher than the target voltage on the 6550 sheet. Does not matter if in fixed or cathode based
-I cannot get the bias adjustment to work properly. It will not allow me to drop below 70ma fully counter clockwise. I have the 15k resistor instead of the 22k according to the update. I also have positive voltage at pin #1 on both power amp tubes I am using KT120 tubes
PostPosted: Thu Jan 28, 2021 11:54 pm
Update:
Amp is fixed! Lots of great testing info from Stephen.
Long story short, my bias pot was bad. As I was investigating it, I cause a few problems that had to be fixed. (Don't accidentally arch the b+ to the heater wires on at the tube pin. Fried the rectifier and hum pot.)
PostPosted: Thu May 04, 2023 3:17 am
Can you share more about how to fix your problem, I have a similar problem.
eggy car
PostPosted: Tue May 09, 2023 3:26 pm
PostPosted: Tue May 28, 2024 12:57 am
Could you elaborate on how you resolved your issue? I'm having a similar one.
candy clicker
