It is currently Wed Sep 02, 2026 5:02 am
 Post subject: Tube cage mounting
PostPosted: Sun Apr 18, 2021 7:35 pm
I haven’t found in the directions and something obvious in the kit hardware that says how to securely mount the tube protection cage. Any tips?
 Post subject: Re: Tube cage mounting
PostPosted: Mon Apr 19, 2021 4:19 pm
I found the hardware. It had fallen behind work bench. It too a magnet on a stick to retrieve it.
PostPosted: Wed Apr 21, 2021 12:25 pm
Yes, just a 1/4"threaded rod with nuts to secure it to the chassis and knurled nuts to hold it in place.
PostPosted: Fri Feb 23, 2024 12:22 am
I located the hardware. It had tumbled behind the workstation. To get it, you need a magnet on a stick.
poly track
PostPosted: Wed Aug 28, 2024 3:06 am
Hey there! I'm having a bit of trouble figuring out how to securely mount this tube protection cage. The instructions are a bit vague. Has anyone else had this issue? Any tips would be greatly appreciated! horror games
PostPosted: Wed Sep 11, 2024 5:00 am
quayhog wrote:
I haven’t found in the directions and something obvious in the kit hardware that says how to securely mount the tube protection cage. geometry dash deadlocked Any tips?
It won't be too difficult, just pay attention to the tube heads, there will definitely be suitable types for you to install, and moreover, you should carefully look at the original sample tubes to be able to classify them and install them slowly. Good luck!
PostPosted: Wed Sep 18, 2024 4:48 am
quayhog wrote:
I haven’t found in the directions and something obvious in the kit hardware that says how to securely mount the tube protection cage. Any tips? fish eat fish
Have you contacted the supplier? They should provide you with all the documents
PostPosted: Fri Jul 25, 2025 3:29 am
Sometimes you need to slightly flex or adjust the cage to align perfectly
avatar world
