It is currently Mon Jun 10, 2024 7:02 pm
 Post subject: B15 build questions
PostPosted: Thu Jul 28, 2022 4:25 am
Hey Stephen
I built the heritage B15, but added your heater elevation circuit before the 1st filter stage of the Ampeg circuit. The amp runs great, but I have a stubborn hum that can only be eliminated by turning the humpot really off centre. I get 1.4V at one side and 4.8V at the other side.
Do you connect your HT CT at the negative side of C21 ?
At the Hoffman site people advise against heater elevation and I argued that. I told that you must have implemented it for some reason and that I trust your expertise on this. Mainly because the 2x 47uf 450V series filtercaps seem more reliable than one 50uf 500V on the Ampeg. Could you shed a light on why you decided to do the heater elevation? Thanks
Also.. Ampeg has only one ground point whereas you and all 18W circuits have 2. I did the 2 ground circuit.. one for preamp and one for all others. It has always worked super for me. Why would Ampeg do it the other way? Any ideas?
Bjorn
 Post subject: Re: B15 build questions
PostPosted: Sun Mar 17, 2024 9:54 pm
I appreciate you sharing this fantastic post. Thank you so much for sharing this content; I really loved reading it.
penalty shooters 2
PostPosted: Fri Apr 05, 2024 5:46 am
You should check to see why there is a stubborn humming sound in the Amplifier. It may be due to incorrect installation using the 2x 47uf 450V line filter cap.
geometry dash subzero
PostPosted: Sun Apr 21, 2024 11:30 pm
While both approaches can be effective, it's essential to ensure proper grounding techniques are followed to maintain signal integrity and minimize noise.strands
