It is currently Fri Jun 12, 2026 11:06 pm
PostPosted: Fri Sep 05, 2025 12:16 pm
Hi Trinity forum,
I have a kit built OSD that i assembled over a year ago.
Its my favorite amp out of the 9 I have. I have noticed that the volume pot is absolutely silent when thr volume is changed when not pulled out for the bright setting but once I engaged thr bright with the pot pulled out its is extremely scratchy if I touch or adj the volume. Does anyone have any insight or suggestions on next steps to remedy this? I have double and triple checked thr build to thr layout and I dont see any discrepancies. PS my amp also has the triolator installed. Thanks for your time and help!
Bart
PostPosted: Wed Sep 24, 2025 2:59 am
Tony Sunshine wrote:
Hi Trinity forum,
I have a kit built OSD that i assembled over a year ago. Pips NYT
Bart
You are really good at building your own OSD.
PostPosted: Mon Oct 20, 2025 6:37 am
Hi Trinity forum,
Bart golf hit
You can use a contact cleaner spray to clean the volume pot, especially the area where the bright setting engages. This can often resolve scratchiness caused by dirt or oxidation.
PostPosted: Mon Jan 26, 2026 5:30 am
Try cleaning the pot with contact cleaner. If the issue persists, consider replacing the pot. Good luck!
