It is currently Wed Jun 10, 2026 2:37 am
 Post subject: PAB Trim pot?
PostPosted: Thu Feb 18, 2021 3:53 pm
Has anyone here tried adding a trim pot to dial in the about of boost on PAB?
How did it work, and how did you do it?
From what I can tell so far, looking online:
I cannot simply insert it in the wire that comes from the footswitch, as that simply turns the relay on or off.
I can't put it in place of the 22m resistor, because that doesn't affect tone.
I think there is probably a way to do it with 2 pots or switches spliced in the wires from the bass and treble controls to the pab relay, but I was really hoping for a one pot "dial it in" type of functionality.
 Post subject: Re: PAB Trim pot?
PostPosted: Tue Feb 25, 2025 5:36 am
You might need to experiment with the specific values of the trim pot (e.g., 10k or 100k) to find the Retro Bowl right amount of boost that works for your setup.
