It is currently Sat Apr 20, 2024 2:14 am
We never tested it at MV=0.
Using the FX Loop
PostPosted: Tue Aug 22, 2023 3:35 am
It's great that you were able to find a solution that works well for both the clean and distortion channels and maintains the overall sound quality of the amp. incredibox
PostPosted: Tue Nov 14, 2023 10:49 pm
Many people talk about the FX loop solution but I still can't figure out what that loop looks like. Can someone explain more clearly? heardle
PostPosted: Mon Jan 22, 2024 10:08 pm
Your approach of moving the master volume pot and adding a voltage divider to the effects loop input NFL Grid seems to have effectively addressed both the distortion and signal-to-noise ratio issues.
PostPosted: Sun Mar 03, 2024 10:06 pm
You can test the difference between the two parts by using them in different situations slither io or with different data to see if there is a significant difference.
PostPosted: Fri Apr 05, 2024 3:49 am
This is a super detailed write-up. Especially cool that you were able to maintain the full contexto output volume.
