It is currently Fri Apr 19, 2024 3:48 pm
 Post subject: Eyelet Board Question
PostPosted: Fri Apr 12, 2019 8:34 pm
Wondering if I have an extra eyelet on my board. The layout doesn’t show the eyelet by my finger in the picture below. Can I just skip it, or am I supposed to do something with it?
PostPosted: Fri Apr 12, 2019 10:01 pm
Looks like a 390R resistor, a small capacitor, and and green jumper go to it, if I'm looking at the right spot where you're pointing on the board. Might look at the layout again. Some times a break will let you see things that you might have missed.
PostPosted: Fri Apr 12, 2019 10:05 pm
PS Looking again, you might also have the green jumper in the wrong eyelet.
PostPosted: Fri Apr 12, 2019 10:27 pm
Also, check the value of the resistor where connects to last orange drop cap at the top. Make sure it's a 24K ohm and it should run down to where the (2) 1M ohm and the 820 cap connect.
PostPosted: Fri Apr 12, 2019 10:34 pm
Was that any help?
PostPosted: Fri Apr 12, 2019 11:29 pm
Definitely helpful. I put it away for the night, I’ll take a look at it tomorrow and see if I can figure it out. Thanks for all the insights!
PostPosted: Fri Apr 12, 2019 11:53 pm
You're welcome. Lotsa of stuff going on in that area. You picked a pretty complicated build, I'm not trying the OSD or the TripTop until I get a few more builds done. Right now, the Tramp is frustrating me!
PostPosted: Sat Apr 13, 2019 3:56 pm
Ok, here are a couple more pics. The eyelet in question is shown on the jumper layout in the builder’s guide, but it isn’t on the layout. It looks like it would be directly under the .022 cap.
PostPosted: Sat Apr 13, 2019 4:00 pm
It lols like it’s connecte to the .022 cap in this picture from the sod amp page on trinity website. Maybe I just jumper it across to the eyelet at the top of the board?
PostPosted: Sat Apr 13, 2019 5:23 pm
download/file.php?id=2203&mode=view This build by a guy in Bangkok has a good view of a stuffed board. Looks like he had enough lead on the .022 cap to just pass over the eyelet in the center. You might want to look at his post. I think stuffing the board will get easier as things progress. If you get really get stuck you can PM Stephen (Coco) using the User Control Panel (upper right hand corner of forum page). Again, I haven't built the OSD and am offering what little insight I have.
PostPosted: Sat Apr 13, 2019 5:32 pm
That is exactly what I neede to know. Thanks for all your help!
PostPosted: Sat Apr 13, 2019 5:34 pm
Check page 61. There may be under board leads connecting to the center eyelet? But I don't see one on the layout. Also, don't think holes to run leads would have eyelets in them.
PostPosted: Sat Apr 13, 2019 5:54 pm
You're welcome. Always willing to share what little I have learned.
PostPosted: Sat Apr 13, 2019 5:59 pm
Found this site to be helpful. http://www.searchingtabs.com/rcolor/rescolor.htm I book marked it on my browser.
PostPosted: Sun Apr 14, 2019 7:55 am
It's extra. You can solder to it and jump to the outside lead or solder to the outside lead and ignore it like in the layout.
PostPosted: Mon Apr 15, 2019 5:12 pm
Build going well? :D
PostPosted: Tue Apr 16, 2019 10:44 pm
Build is going pretty good, thanks. I messed up checking voltages and fried my rely board, so I’m back to waiting on U S Customs.
Hoping to crank it out quickly once I get the new board from Stephen!
PostPosted: Mon Apr 29, 2019 9:59 pm
May have to order a OT for my Tramp! If I fried it, I'll be waiting on Customs, too!
