It is currently Mon Jun 23, 2025 12:21 am
We never tested it at MV=0.
Using the FX Loop
PostPosted: Tue Nov 14, 2023 10:49 pm
Many people talk about the FX loop solution but I still can't figure out what that loop looks like. Can someone explain more clearly? heardle
PostPosted: Mon Jan 22, 2024 10:08 pm
Your approach of moving the master volume pot and adding a voltage divider to the effects loop input NFL Grid seems to have effectively addressed both the distortion and signal-to-noise ratio issues.
PostPosted: Fri Apr 05, 2024 3:49 am
This is a super detailed write-up. Especially cool that you were able to maintain the full contexto output volume.
PostPosted: Thu Mar 13, 2025 3:46 am
While you won't notice a big difference, adding a voltage divider before the fx may reduce some Poly Track of the signal's energy before it reaches the PI. This can be further tested by comparing to an unmodified analog amplifier.
PostPosted: Tue Jun 10, 2025 3:04 am
However now the distortion channel got a reduced output obviously which could be an issue, so to compensate for the new additional signal reduction Baseball Bros IO changed the ratio output pot VR8 of the distortion section from 100k to 250k and bridged the 150k R24 series resistor.
