It is currently Sat Dec 09, 2023 4:58 pm
We never tested it at MV=0.
Using the FX Loop
PostPosted: Tue Aug 22, 2023 3:35 am
It's great that you were able to find a solution that works well for both the clean and distortion channels and maintains the overall sound quality of the amp. incredibox
PostPosted: Tue Nov 14, 2023 10:49 pm
Many people talk about the FX loop solution but I still can't figure out what that loop looks like. Can someone explain more clearly? heardle
