It is currently Thu Mar 28, 2024 8:02 am
 Post subject: Bias'ing help
PostPosted: Fri Mar 20, 2020 6:04 pm
Hey all!
I just got a Laney GH50L and i'm trying to check the bias, but something here seems amiss...
i was following this video...
https://www.youtube.com/watch?v=RIUm8_7hpMI
and following this schematic...
https://www.thetubestore.com/lib/thetub ... ematic.pdf
when i try to check the ohms, as show around the 36:13 mark...using the schematic, the black wire is point 42...but when i set the multi-meter to ohms, measure from the black wire to pin3 of the output tubes, i'm getting 50ohms...seems crazy high...
when i do the same measurement with the amp on, for the milliamps, i am getting 1.0
when i read the plate volts from pin3 to 8, i got 406V...
That means, if I've read this right, the tubes are working at 8.12W...for EL34s...
i've obvisously done something wrong...the only thing i didn't do that he did, was drain the caps...do you really need to do that?
 Post subject: Re: Bias'ing help
PostPosted: Fri Mar 20, 2020 6:49 pm
update...drained filter caps...pin1 from V1 to ground...no change in the 50ohm
PostPosted: Fri Mar 20, 2020 10:04 pm
The schemaic you poster is for the 100l
I asumme theres no 1R resistors in the amp to make life a little easyier?
PostPosted: Sat Mar 21, 2020 12:37 am
Interesting video. That's certainly one way to do it and it avoids needing special socket adapters or installing 1-ohm resistors on the cathodes.
I assume the 50L is the same as a 100L, just with two fewer EL34s for 50 watts.
Your math is right, but 50 ohms for a transformer winding does seem high. Are you sure you are measuring to the center tap of the output transformer's primary? Try removing the EL34s and measuring from pin 3 on one socket to pin 3 on the other socket. If you get 100 ohms, then your 50 ohm reading from before was OK. Otherwise just divide whatever you read by 2.
If you can find a place to measure the bias voltage, like at the junction of the two 220k resistors leading to the grids, what does it read? Is it in the -35 volt range? Also is the bias switch in the right position for EL34s?
PostPosted: Sat Mar 21, 2020 8:50 am
Thanks for the help Mitch!
The 50 is the same as the 100, just two less tubes, as i understand it...this schematic comes with the 50 model
I didn't take the tubes out...but measuring off R34 and R38, which at the time was escaping me as bias points, the amp was shooting 38v
I know the schematic says 35, but based on this chart, thats low, so i left it at 38...shoot the middle ground...i tried to say w eber chart but for some reason, once posted it changes to BBQ??
http://www.tedweber.com/webervst/tubes1/calcbias.htm
Also left a note inside so that the next time, i remember a little easier! Unless i dont have this right?
Thanks all!
PostPosted: Sat Mar 21, 2020 12:11 pm
Opened it back up...
Here is what im getting
Plate 417V
V5- 47.8ohm and voltage drop of 1.36V
V6- 49.7ohm and voltage drop of 2.68V
If i increase the bias, V6 is going to burn out, no?
Changing the voltage drop across V5 to 1.75V leaves 3.58V at V6
So...i took out V6 and put a spare EL34 in...
Now i get
Plate 416
V5 - 48.1ohm and 1.23V drop
V6 - 50.2ohm and 2.08v drop
So, i guess it stays there until i can get a matched set...well, better than the matched set it came with...unless im missing something?
I bumped the bias up a bit...the drop now is 1.68V and 2.55V for V5 an V6 respectively
PostPosted: Sat Mar 21, 2020 2:57 pm
To finalize..
I take the 416 x (1.23/48.1) = 10.63W....the miiliamps being 25.6, which is low for an EL34, but with the other tube reading 41.4 milliamps, thats a little hot...correct?
Will order a matched set after all of this...but i'm doing this right, correct?
PostPosted: Sun Mar 22, 2020 2:21 pm
You are doing it right. Sounds like your EL34s are just mismatched. Try swapping their positions and see if the readings are more equal.
