It is currently Thu May 16, 2024 5:59 am
PostPosted: Fri Jul 22, 2005 10:53 am
Steven,
I am in the same boat. I have been thinking about a Metroamps Superbass. I am afraid that the Bassman might be underpowered? I wonder what ever happened with bnwitt's Marshall Major project?
Broz
PostPosted: Fri Jul 22, 2005 12:24 pm
Marshall Major? Holy cow!!
Man, knowing what I know now...I dont think I'd own or build a tube amp bigger than 30-40 watts. I can't imagine having a 200 watter lying around....
PostPosted: Fri Jul 22, 2005 3:03 pm
was thinking something a little more uncomon, might do a trainwreck, always could do a 59 super lead so i could be jimi of maybe not jimi but have a lot of volume any way, what about an ef86 front end with a super lead 4 el34 power section, thay would be uncomon.
just tring to brain storm any thoughts. ?
PostPosted: Fri Jul 22, 2005 4:33 pm
Frank,
I agree for guitar, but pushing air for bass is a little different.
Broz
PostPosted: Fri Jul 22, 2005 4:48 pm
Oh, this is for bass? Ahh..sorry! :)
Bass, a bare minimum wattage is 100 watts.....if not more...
PostPosted: Sat Jul 23, 2005 12:34 pm
What sorta bass sound in what sort of setting? There's all sorts of answers, only some of which are good in certain instances. (A good 50-60 watts can sometimes be just fine for bass, like old Ampeg flip tops.)
Bear
PostPosted: Sat Jul 23, 2005 12:41 pm
Well, let's start with a low powered version. The Bassman was not 300W.
Basic amp, minimal frills, for a non-professional player.
PostPosted: Sat Jul 23, 2005 6:27 pm
Well, the Tweed Bassman was a 50 Watt Bass amp before it was hijacked by the blues and rock players. With ten years or so trying things I think Fender got it right in the 59 model then everyone got sold the high power is best theme from the manufacturers. I have used the 59 with a bass and I think it sounds great, I was thinking of putting together another bass amp prior to building the 5F6A but I won't bother now. If they don't like it it's an easy sell at the end.
Nigel
PostPosted: Sat Jul 23, 2005 7:22 pm
So, the circuit you recommend for a Bassman build is the 5F6A then?
PostPosted: Sat Jul 23, 2005 10:03 pm
The blackface Bassman heads can actually be pretty good for bass. what's good about them is there's less preamp gain and more voltage swing on the power stage, with sag-free solid state rectification and some hefty output iron. Kind of goes the same for Showman heads, too.
I think the irony has been pointed out that the 59 Bassman reissue is electronically a better bass amp than the original do to higher plate voltages and the solid state rectifier. If you need to do tube rectification on a new build for bass, use two as was original equipment - much less sag.
Bear
PostPosted: Sat Jul 23, 2005 10:08 pm
Yeah, I was pleased with the 5F6A build but remember I built it as a guitar amp not for bass. Not being a bass player and only using it on lowish volumes works OK but I have not cranked it with the bass so can't comment on the rectifier sag, however it wouldn't be too difficult to replace the tube rectifier or maybe even use a copper cap?
Nigel
PostPosted: Sun Jul 24, 2005 9:44 am
I would love to make a mid 70's SVT. I had the pleasure of using one for a few years in the late 80's and really don't think there's an amp out there that sounds as good with my Jazz Bass. Sonic nirvana... Perhaps a Portaflex B15 comes closer then most.
PostPosted: Sun Jul 24, 2005 9:57 am
I guess google is really that good.
http://www.drtube.com/guitamp.htm
