It is currently Fri Mar 05, 2021 5:48 pm
 Post subject: Reissued Mullard 12AX7
PostPosted: Fri Sep 20, 2019 6:01 pm
Has anyone tried the re-issued Mullard 12AX7. If so, what are your impressions of it and the other Mullard re-issues?
PostPosted: Sat May 09, 2020 2:15 am
I've used them in a Dual Terror and the Egnator amp from the seminar (20 watts). They sound much better to my ears than the JJ's both those amps came with. Great cleans...good break up and sound pretty clear with the medium/light crunch I typically use. I know they aren't the NOS ones... but I would consider them a step up from the JJ's.
PostPosted: Sat Feb 20, 2021 5:44 am
My hubby using the Egnator amp, and they sound too good and better than before, he bought it from Reecoupons last month, if you wanna buy check on there, you will find more options.
