It is currently Fri Apr 03, 2020 4:45 am
 Post subject: Tramp Specs
PostPosted: Fri Jan 01, 2010 12:19 pm
TRAMP SPECIFICATIONS
1. Controls: Power, Gain, Bass, Treble, Volume, 1 input
2. VRM [DC power level control] incorporated into design
3. Amp to be able to go from Clean to Dirty.
4. Drive octal tubes with OT & bias changes
5. Cathode Bias
6. Solid State rectifier
7. 2 tubes (3 max)
8. Beginner build
9. 1 additional Noval socket (power or pre-amp)
10. LED Power Indicator
11. Tweed/'tude switch for clean/dirty preamp
12. Headphone output
Possible options: line out, drive EL34 tubes, VRM may be optional
Power / Level control – Rotary ON-OFF switch with 1M control for VRM*.
Actions: Off – On (low level is standby. Turning control further effects the VRM control and the power level of the amp.
*VRM– components mounted on eyelet board. MOSFET mounted immediately beside board & leads soldered in directly.
Gain control – to adjust amount of overdrive. Note: Amp has to be able to go from Clean to Dirty.
Tone Controls:
Bass – Cut/Boost
Treble - Cut/Boost
Master Volume control – overall volume level control.
Target price for Kit or Amp build - less than a Deluxe but more than a Champ.
PostPosted: Fri Jan 01, 2010 10:51 pm
How do you manage a headphone jack on a tube amp? Is there some way to load the output with resistors or...?
AJC
PostPosted: Sat Jan 02, 2010 12:31 pm
AJC
Loading resistor of 10 ohms and a small resistor/cap. We'll see how good ours is soon.
PostPosted: Fri Mar 26, 2010 9:57 am
Any chance power scaling could be incorporated into existing built amps? Like the 18 watter, sIII, TMB, etc?
PostPosted: Fri Mar 26, 2010 1:39 pm
You'd have to install it yourself. You need a liscence to commercially use Power Scaling. Here's the appropriate kit for the "18 watters" http://www.londonpower.com/catalog/prod ... ucts_id=99
PostPosted: Fri Mar 26, 2010 6:32 pm
Just use the VRM, it's easier :D
PostPosted: Fri Mar 26, 2010 8:24 pm
:thumbsup: :thumbsup:
 Post subject: Re: Tramp Specs
PostPosted: Thu Apr 08, 2010 9:44 am
Stephen, have you grounded on the chassis dimensions? I know we had a discussion about it a while ago.
Also, is it going to be a combo type similar to the Deluxe or with top-mounted tube sockets like the heads?
SG + Brit tube head = Nirvana
PostPosted: Thu Apr 08, 2010 11:28 am
Current plan chassis size is : 14" W X 5" D X 2.5h
Fender tweed style. But with only two tubes and 5", I don't see why we/you couldn't punch two holes in the top as well. Any comments on that idea?
PostPosted: Thu Apr 08, 2010 2:16 pm
Might be nice to have the option of a head or combo. Depends on real estate availability in there I suppose. I was going to build it as a head regardless, but I may consider fabbing a chassis from a blank to fit a head cabinet I have. Gotta check the measurements of the cab.
Will the lettering be silk-screened on the chassis or will there be panels?
PostPosted: Thu Apr 08, 2010 2:53 pm
This time, there will be mirror finish aluminum /chrome panels with white silkscreening. That's the plan so far.
PostPosted: Fri Apr 09, 2010 12:00 pm
I think I would like that, I have several cabs that a lower watt head would be good for basement work or miced if more volume is needed.
Tele's make the best noise
PostPosted: Fri Apr 09, 2010 12:32 pm
I would definitely NOT expect this as a kit option, but I'm seriously considering hanging one upside-down in a BF/SF Champ-style chassis & head cab I have floating around.
** b0b0 **
- This Space For Rent -
PostPosted: Sat Apr 10, 2010 12:05 pm
Is it still going to have an extra nine pin tube hole? I want a mic input!!!!!
PostPosted: Wed Apr 21, 2010 7:02 am
Kit Pricing & Details here: Tramp Kit Details
