It is currently Tue Jun 04, 2024 5:44 am
PostPosted: Wed Oct 20, 2021 4:22 pm
Hi Everybody - I have just completed the tramp build, which I will be using with an external 1x12 cabinet.
Does anyone have any tips or experience on ways to enclose the amplifier that won't be going into a combo unit? The dials are on the front, tubes sticking out "the back", transformers on top and an open bottom with all of the wiring. I'm not sure any of the head cabinets will work for this amp layout.
At minimum, looking for something that can cover up the bottom exposed wires
Dave
PostPosted: Sat Nov 06, 2021 11:00 pm
Contact Stephen, if I recall, you can get the chassis drilled for either combo or head configuration (head version is a little tight for wiring in the head config, though). I've tried figuring out how to set up combo chassis in a head config, but haven't figured out how to (yet).
