mitch m wrote:
Fender didn't go overboard with some of the things that could be done to reduce noise, like neat heater wiring, star grounding and using shielded cable. Trinity's 5E3 layout does, however. Sounds like running that wire "out in space" as you have done is OK as far as noise goes. But if you ran it under the board the way the layout shows, without it being shielded, it could be a different story.
Glad you got the amp working. If you are happy with the way it sounds just leave the wire as it is. It's in a sensitive part of the circuit, though, and I would replace it with a shielded one. It won't change the tone of the amp. It will just make it more immune to picking up stray hum and noise which is a good thing.
Too bad you don't have nuts to secure the board. You should be able to get some at your local hardware store. They are quite common.
Thanks for your advice, Mitch, much appreciated.
I finished up the amp this morning, after getting some nuts to secure the chassis. Sounds great! Very impressed with the Trinity Amp Kit. Hopefully, a Marshall kit will be in the near future!
I ended-up snaking that wire under the board (before you said bad idea...lol) but put the shrink-tube around it...I don't notice anymore noise that when I had the blue-wire suspended above the board. Unlikely that I'll actually gig this amp, as it will lack the headroom, but maybe it would be noisier in some of the venues we play at with poor electric and lighting...I can always change it. I would like to get the coaxial-cable sent to me, in the event it's needed in the future though. I'll try and contact Stephen. Thanks again, Mitch.
