G'day,
First amp build/first post.
I'm having a great time and enjoying the build but have a problem.
With all tubes in and a load connected within 5 sec the speaker started to hum and the 4K7 (R22) started smoking.
Here is what I know:
The colour code of the resistor shows it to be more 470 Ohms(Yellow, Violet, Brown?, Gold) but it measures out at 4.58K Ohms on my meter??
Mains Voltage 241V (Australia)
With no rectifier in place:
V5 pins 4= 358V & pin 6=358V.
Across pins 2 & 8= 5.6V
V4 Across pins 2 & 7= 4.47V
V3 =4.45V
V2 Across pins 4-5 & 9= 6.46V
V1 =6.46V
Rectifier installed with no other tubes.
B+ =470VDC
Before powering up I checked the grounding and continuity allover. All being good.
I'm in the process of double checking everything and I will swap out R22 for a new one when I can get one.
Any ideas would be greatly appreciated.
Ross
