It is currently Fri Jul 10, 2020 6:37 am
Post new topic Reply to topic  [ 43 posts ]  Go to page Previous  1, 2, 3
PostPosted: Sun Nov 04, 2018 11:38 am
Suggest you measure B+ at beginning on full and then at your setting. When it starts to fade, do it again. If the voltage is significantly different, then yes, if not, then check tubes.
PostPosted: Sun Nov 11, 2018 4:05 pm
This is frustrating, a week of playing and no issues. The investigation continues...
Everyone must believe in something, I believe I will go canoeing. - HDT
PostPosted: Tue Mar 03, 2020 9:03 am
It refers to the volume pots being scratchy. This is caused by a small amount of DC voltage that is present. That DC voltage is also present on your pickup's as well assurance invalidité. So install those blocking caps if you want to get rid of the scratch and not have to worry about DC voltage on your pickups.
VRM won't change the tone of amp like your thinking. Just a very useful volume controlling device.
With VRM you still get the Hi and Lo inputs, that shouldn't change.
Thank you very much for giving us all of this information. It's really cool on your part.
