Hi everyone.
I've almost completed my second Trinity build (the first being the sIII) and I'm having a problem I can't seem to troubleshoot.
(Build diary and pictures to come later).
Here's what the voltages were before I plugged in the power and preamp tubes.
AC Mains voltage - 118 VAC
B+ - 476 VDC
However, when I plugged in the preamp and power tubes, only the rectifier is glowing (normally).
And here's the readings (with normal in parentheses) -- they're off the chart:
V1
Pin 1 - 422 (120)
Pin 3 - 0 (2)
Pin 6 - 424 (123)
Pin 8 - 0 (2)
V2
Pin 1 - 423 (167)
Pin 3 - 0 (1.1)
Pin 6 - 440 (123)
Pin 8 - 0 (70.5)
V3
Pin 3 - 478 (380)
Pin 4 - 478 (338)
Pin 8 - 0 (22)
V4
Pin 3 - 478 (382)
Pin 4 - 478 (339)
Pin 8 - 0 (22)
I would think there's something wrong with the way I hooked up the heater wires.
Here's my hand-drawn diagram of how I hooked them up (minus the twisting for clarity). In the Trinity document it looks like there's only one wire going in to Pins 7 and 2 on V3. I'm daisy chaining into those from V4 and then out to V2 and V3. Is this right?
