It is currently Sat Apr 04, 2020 8:26 am
PostPosted: Tue Mar 24, 2020 3:48 pm
Just curious what the 2 red X's represent on the layout between the.01UF cap and the220K resistor? Looking forward to playing this amp!
PostPosted: Tue Mar 24, 2020 7:14 pm
Probably has to do with where you would insert an effects loop into chan. 2. Look at the revision list at bottom right corner of layout sheet. Ignore the X'es if you aren't putting in an effects loop and wire as shown. If you are adding an effects loop, look thru TC-15 forum for more info and maybe Back Stage> Resources, too. If I find it, will post link(s).
"You can always tell a German, but you can't tell 'em much!" ( Momma Ruth)
PostPosted: Tue Mar 24, 2020 8:12 pm
Thank you so much, makes perfect sense. I doubt I'll do an effects loop at this point. I run a Fryette Power Station in my rig and it has one. Consider it ignored.
i
