It is currently Wed Jan 22, 2020 6:22 pm
Post new topic Reply to topic  [ 23 posts ]  Go to page Previous  1, 2
PostPosted: Fri Aug 12, 2011 5:36 pm
b0b0 wrote:
The shield should only be connected to ground at one end of the cable.....typically at the jack or pot. The shrink tubing covers the exposed shield wires at the opposite end to prevent anything from contacting them & shorting to ground.
Gotcha. Makes perfect sense. I just thought that, for a moment, somebody was going to major extremes to prevent the shield from that other end from shorting on anything (i.e. by peeling it back, then snipping it off, then covering it with heat shrink).
PostPosted: Fri Mar 16, 2018 2:38 pm
This little picture tutorial was just what I needed. Thanks!
PostPosted: Wed Sep 25, 2019 1:39 pm
I would enthusiastically recommend Klein wire cutter/strippers #11055 and #11057. The 14 AWG solid/16 AWG stranded stripper hole on the 11055 cuts the outside insulation almost perfectly from the RG-74U (Edit: RG-174U) cable while leaving the shield uncut :!: And, at least to the naked eye, both cutter/strippers leave wires without nicks :!:
"You can always tell a German, but you can't tell 'em much!" ( Momma Ruth)
