Hi everyone,
I built a Telecaster copy last year from scratch, really happy with how it turned out and decided it needed an amp. Settled on the Tramp and just got it up and running but have a few questions and could use some feedback on measured voltages. I'm a true beginning guitar player but have a good friend who is pretty darn good. Tramp is getting rave reviews from him! Next step will be to build a cab head and matching 1x12 cab. I have a wood shop and am looking forward to making something nice out of fancy mahogany for the Tramp.
Here's my guitar:
File comment: DIAVOLO "Soulcaster"
And the innards of my Tramp build:
Had a few issues but by following the guide, spending quality time with the schematics, reviewing pretty much all of the Tramp forum posts and taking the time to not kill myself I got her done. She's hooked up to a 12" Celestion Gold 8 ohm speaker.
Still have a few potential issues though, highlighted in Red:
1. I added a second switch for the Load Switch EL34 option. I used the exact same Carling switch Trinity provides for the Bias switch. Upon testing with the 12AX7/6V6S JJ tubes Trinity provided with my friend playing a Strat at pretty high volume settings I noticed a couple of flashes. Settings were for the 6V6S but were got some arcing on the Load Switch contacts. Lowered the volumes immediately and it stopped. Anyone else seen this?
Should I be using a higher amperage switch for the Load? Also thinking about insulating the solder contacts if the switch is capable of supporting the current. My solder joints look ok, nothing excessive reducing separation.
2. Voltage Checks:
I'll list my measurements for 6V6S, but not yet for the 6L6GC and EL34 power tubes. You'll see my question on these tubes below. All are JJ as is the 12AX7.
JJ AX127/6V6S
AC Main 120.5 VAC
Power xfmr primary in is 646 VAC target is 630 VAC, is this ok?
Heater is 6.8 VAC target is 6.3 VAC, is this too high?1st cap is 437VDC, target is >400VDC
B+ set to 400 VDC with VRM
B+2 is 397 VDC target 397 VDC
B+3 is 334 VDC target 327VDC or is target 340 VDC per the schematics?V1 12AX7
Pin 1 191 VDC target 203 VDCPin 3 1.7VDC target 1.7 VDC
Pin 6 193 VDC target 191 VDC
Pin 8 1.6 VDC not exactly sure of target, what is on vs. off on the Tramp Voltage Chart?V2 6V6S
Pin 3 396 VDC target is 398 VDC
Pin 4 395 VDC target is 395 VDC
Pin 8 28.7 VDC target is 29.7 VDC
I have the 6L6GC and EL34 measurements as well but before I jump into my questions just need to verify that you cannot get B+ to 400 VDC using the VRM. Hopefully that is correct (I can get 387 VDC with VRM set at max, same for both tubes). Should I be using a different VRM output to measure performance on these tubes?
Good news is that the Tramp rocks! Nothing is melting, no smoke or crazy heat (Those 5W bias resistors do get pretty darn hot with things turned up!). I haven't taken a heat measurement yet but just remembered by DMM apparently can measure temp.
Thanks up front for your feedback. This was a lot of fun!
Cheers, Keith
