A week after the course, I wanted to post my results, but before doing so I wanted to thank
Stephen and Chris again for all their efforts. I can’t say how impressed I am with the
follow-up support, both via email and through this forum.
I should also add that I have an unfair troubleshooting advantage; I have a Tramp combo which Stephen built for me last fall.
When I left last Sunday night, the head was completely wired but I was getting no sound through the
speaker. Both Stephen and Chris looked at it and nothing was obvious.
Since then, I used the chopstick method and found one connection which was bad (from the
volume to the impedance switch). I corrected that and also cleaned up some
of my work. I also spent a few hours double checking everything and cross
referencing to the tramp combo.
I am now getting sound through the speaker but the power level is acting
like a volume pot (at the 6 position there is virtually no sound, at max
position the sound level is virtually the same as the tramp combo but
perhaps a bit thinner). On the Tramp combo, the difference between the 6 setting and max
on the power level to me is more like an audio presence control but the volume level is almost the same.
This testing was done using the same speaker and all controls at the same setting (6 on the dial).
I also swapped tubes back and forth between the head and the combo to ensure it wasn't a tube problem.
I have checked the 2 100K resistors around the Power Level pot and found they were both accurate (I removed the one
attached to the 50uF cap to measure it).
The voltage readings for the two amps are as follows (I used the voltage points from the layout provided).
The last thing I checked was the power level pots. The combo is a split shaft marked B1M. The head has an Alpha marked A1M (does the A mean Audio Taper and if so, would this be a factor?).
Any ideas on the cause of this problem would be appreciated.
Thanks, Scott
