It is currently Thu Jun 27, 2019 12:21 am
 Post subject: Build pics Triwatt V3.2
PostPosted: Tue Jun 04, 2019 1:00 pm
Thought this could help everyone out who is intended to build a Triwatt since the build pics in older topics might have a little different appearance. I really enjoyed this build so much!
Hope this could be of some help!
Feel free to comment on the build. It's my first, so comments are more then welcome!
Cheers!
Gertjan (The Netherlands)
File comment: Turretboard - Bottom jumpers
File comment: Turretboard - top
File comment: V3 Close up
File comment: V1 Close up
File comment: Hardware installed
File comment: Power section Close up
File comment: Bias hardware Close up
File comment: PT on chassis
File comment: OT on chassis
File comment: Heater and bias wiring
File comment: Heater and bias wiring 2
File comment: Bias wiring close up
File comment: Bias and OT primaries wiring close up
File comment: Turretboard wiring (first part) + OT secondaries wiring with impendance switch + output jacks
File comment: Turretboard wiring (first part) + OT secondaries wiring with impendance switch + output jacks - top view
File comment: Output section wiring close up
File comment: Turret board wiring (part 2)
File comment: Turretboard wiring (part 2) top view
File comment: Pot wiring (part one)
File comment: Pot wiring (part two) + shielded wires
File comment: Pot wiring (part two) + shielded wires 2
File comment: Complete build - top view
File comment: Complete build - dissection (right side)
File comment: Complete build - dissection (middle part)
File comment: Complete build - dissection (left part)
PostPosted: Tue Jun 04, 2019 9:17 pm
Hi Gertjan. Welcome to the forum!
Good job on the build. Really neat and tidy. Thanks for the detailed pictures.
I'm sure you will have as much fun playing it as you did building it.
PostPosted: Thu Jun 06, 2019 3:51 pm
Much thanks for the detailed pics! I am in the process of building mine right now...had to take a break after getting the bias circuit wired several weeks ago but hope to start up again this weekend.
PostPosted: Thu Jun 06, 2019 5:15 pm
Thanks for the kind responses! And yes I enjoy playing it as much as building it. I used a lot of images from others during the build so I figured I might as well take some decent pictures after each step to help others out!
@PhamRock good luck with yours!
I do however, find that the amp is lacking a little bass.. anyone got a clue as to what could be the problem. Or could it just be the nature of an Hiwatt, I've never player one before. My Laney L5 Studio has quite a bit more of it. Discussed this with Steven already, but all voltages are correct. He suggested some cap swaps although nobody had ever indicated that it lacked bass. Would swapping to KT66 tubes give me some more bass? I'm using it with 3 Sovtek 12AX7 tubes, 1 Jan Philips 12AT7WC and two JJ 6V6's plugged into a EVM12L (also used a V30 and ET65).
PostPosted: Fri Jun 07, 2019 11:04 am
We did suggest changes to the bass control. We typically use Tung-Sol 12AX7s and NOS GE 12AT7 and JJ PI with 6V6. The KT66, has a bit more bottom end, but not that you would notice if you think it is bass light.
We recently tested two here and have no concerns for the bass response in the standard circuit. It might just take getting used to. It's like playing a hi-fi!!
PostPosted: Fri Jun 07, 2019 12:30 pm
Thanks Coco! I have yet to test these different cap values but it could just be the nature of the amp, guitars do not need a lot of bass naturally so maybe I got used to a little much bass haha.
Cheers!
PostPosted: Fri Jun 07, 2019 4:45 pm
I have tested and played some more with the amp and I figured it's just the nature of the amp. It has a different bass control and response then the laney. As Coco indicated: more Hi-Fi! I love it!
Thanks for designing such an awesome Hiwatt
Clone for bedroom volume (don't be fooled tho, it can get really loud). It's also true what the description says: none of the settings sound harsh or flabby. You can get many great tones out of it! I think I'm gonna marry it!! Lol
Cheers!
