It is currently Thu May 16, 2024 12:58 am
 Post subject: TC-15 Test Drive
PostPosted: Fri May 25, 2007 10:14 pm
Hey everyone,
Thanks to coco, I got to take the TC-15 prototype for a drive. I have
recorded a few clips, which I'll get to, but first the rig.
I plugged the head into a Traynor Bass cab with a single 8ohm 15 speaker
(Don't know what it is, but its vintage 1970's). Not sure how many of you
would do that so I won't go into detail on the sonic properties of the
speaker and cab. Recordings were made with coco's attenuator to keep the
family from complaining.
No effects used, natch! Guitars - Mid 80's Korean Squire Strat with Fender
Lace Sensor pickups, Blue in the neck and middle positions and a Silver in
the bridge position. I did the cleaner stuff with that on the Treble Bass
channel, with some dirty stuff on the One track by switching the guitar
cable(hence the pause).
Amp settings - In O'Clock (No markings on faceplate yet)
Code:
  Master       |              Channel 1              |       Channel 2 (EF-86)
  Vol  |  Cut  |Treble | Bass |   Vol | Toggle switch | Contour |  Vol
  12   |  12   |   5   |   2  |   9   |      Down     |    12   |       5
Please be aware that I will never be mistaken for James Hetfield or any pro
guitar player, so there's plenty of flubs...just so you know before you
click.
Both tracks with the strat:
http://www.trinityamps.com/clips/JPclip ... Bridge.mp3
http://www.trinityamps.com/clips/JPclip ... rtyOne.mp3
The following tracks were done with my 95ish stock Gibson explorer, which is
a 76 re-issue. Only thing to say about he Explorer is I use Ultra heavy 12 -
54 Strings because I usually have it tuned down to B for the KoRn,
Disturbed, etc, type stuff.
This clip is Metallica and Slayer tuned down:
http://www.trinityamps.com/clips/JPclip ... inMask.mp3
I tuned the Explorer to E (ish) for the Purple and Ozzy stuff:
http://www.trinityamps.com/clips/JPclip ... Master.mp3
http://www.trinityamps.com/clips/JPclip ... plorer.mp3
In summary this amp has plenty of versatility and gain enough even for a
metal head like me, I'm sure I can dial in quite a range of sounds with this
bad boy! I hope to try some and record some more sounds, maybe even without
the attenuator this coming weekend! Just got to get the wife and kids out of
the house for a while.
Thanks to coco for the opportunity to try this amp!
John.
PostPosted: Sat May 26, 2007 6:32 am
Thanks for the clips. This really shows the TC-15 in a different light. Certainly this demonstrates some of it's versatility.
Reminder: These were recorded after using an attenuator into a 15" speaker.
Need more... 8)
PostPosted: Mon May 28, 2007 9:10 am
Hey coco.
Just wanted to say thanks again for the chance to play these amps! I might be able to talk with some authority on amplifiers some day. I might even learn how to use master volumes and volumes less than 10 - doubt it!
John :P
